So I'm working on my 2012 moonlight white Infiniti (I don't have reason to believe it has the scratch shield). I'm using MT300 with Ultimate Compound, Meguiars Yellow softbuff 2.0 pad.
Defects: Horizontal surfaces have some fairly moderate water spots with very very very minimal swirl marks, and some marring here and there (some light scratches that don't terribly fail the fingernail test, and some that do not fail the test) and some light haze.
I did a test spot (on the hood upper right). I did first round with 5 passes, I'd say moderate pressure (enough pressure to keep the pad rotating 1x - 2x per second), slow arm speed, 2x2 section, taped off, at 4800.
First pass got rid of the swirls, most of the marring, and i'd say reduced the water spots 50%? I noticed I exceeded the work time because the product was starting to dry and threw very tiny balls of product. I primed the pad with product with a credit card, and I only used about five pencil eraser sized drops on the pad (probably too little). I misted very lightly some water to lubricate the dried spots so I could wipe effectively. cleaned the pad in the pad washer, got the pad 95+% dry.
Then I did a second pass, I put a light X on the pad with product, turned it on lowest setting to move the product around, then back to 4800. This time I adjusted my arm speed to be faster, but still kept the same pressure, did four passes. It really didn't do much better. Some of the scratches were now lighter. I decided I could live with the results (not that I wanted to, but felt like I had to because I don't want to cut through the clearcoat... I don't have a paint meter so I don't know much I'm removing. The car was in reasonably good condition meaning, some very slight haze, and no reason to believe the clear is very thin.)
I did the rest of the hood and also did a second pass along the bottom of the hood along where the hood meets the bumper as this section seemed to have the most defects on the hood.
Here's what I'm worried about. I'm worried that I cut too much because the test section (remember 2x) and the bottom of the hood 2x, these sections have squeak when i rub my finger across them, but the rest of the hood DOES NOT. Why???? Did I remove too much Clearcoat???? What did I do??
I clayed the surface prior using quick detailer, but I did NOT rewash, and did NOT use IPA wipedown prior to ultimate compound. Someone please help me, calm me down, please tell me I'm over-reacting and it means something good... Why would the spots I did 2x on sqeak with my finger and the others do not???
Here are my additional questions:
1. When using Ultimate Compound, Do I put an X on the pad (trying to figure out how much I need)? The Microfiber D301 system uses only pea sized drops...
2. When using the pad washer with wolfgang pad werks cleaner sprayed on the pad, then drying it, am I supposed to re-prime the pad? If so with what? How?
3. I thought UC had a long work time... what is a long work time considered? I noticed flashing after using reasonly medium arm speed, 2x2 section (or 3/4 of that) after 4-5 passes with medium pressure (as much as I could to keep the pad rotating I'd say 1x - 2x per second). I would've thought long work time meant I could do double that....
hhhhhhhhhhhhelp.....
