I've always read the advice that you should not let your car air dry, because of water spots, which in the long run, may affect the paint?
What happens if you live in a state or city, where raining happens quite often, you will get water spots as well, basically, throwing that whole logic out of the window. For example:
- It could rain at 2am while you are sleeping, and now you wake up at 7am and your car has water spots. You can't prevent this.
- It could rain while you are going to work and don't have time to dry the car, you will also have water spots.
- It could rain while you are going to a party or gathering, where you don't have time to dry the car, you will also get water spots.
- It could rain while you are inside the house, would you wait for the rain to be over, and go outside to dry your car? I doubt it.
- It could literally rain once a week, while you are sleeping, and it would be exactly the same as if you washed you car and let it air dry once a week, in fact, it would be worst, because the rain is probably harder than tap water.
Bottom line, if you cannot dry your car or don't have the time, don't worry so much, nothing bad will happen, the "negatives" of air drying are grossly exaggerated, especially, since raining, while you are sleeping, does the exact same thing to your car, without giving you time or notice to dry it with a micro fiber towel. This, assuming, you don't have a garage, which most people don't.
"Air drying" your car once a week, won't do anything negative or worse than raining already does.
