Meguiars ultimate detailer and ultimate quick wax
  • Meguiars ultimate detailer and ultimate quick wax
    Do either of these stain plastic or rubber. Are they both ok to use on these surfaces or even window do that matter?
    Re: Meguiars ultimate detailer and ultimate quick wax
    Both products are safe on the surfaces you mentioned. They will not stain.
      Thanks. Will either of these protect plastic?
        Hi Ron,
        Meguiar's has a variety of "Quik Detail" Sprays. They are all primarily for safe, light dust, fingerprint, or any light contaminant removal. They allow the user to safely remove these contaminants, in a easy spray on/wipe off type application. Remember to work on a cool surface ideally in the shade, and use a premium microfiber towel. Each one of Meguiar's "Quik Detail" Sprays each have their own unique characteristics as well. For example, Meguiar's Ultimate Quik Detailer will provide added gloss, a super slick application, and added water beading from it's included hydrophobic polymers. Meguiar's Quik Detail sprays are mainly designed for use on paint. They will not dry white on a non painted surface, and technically could be used on glass, but, they do not perform as well as a dedicated glass cleaner for use on glass.
        Meguiar's has a variety of "Quik Wax" Sprays. They are primarily used to boost the life of your original wax coating, and in fact, they will actually significantly increase the life of your original wax coating when used regularly. Our Quik Waxes should be used on a clean surface. Our Quik Waxes are also recommended to be used with a high quality microfiber towel, such as our X2020 Supreme Shine Microfiber Towel. Quik Waxes are typically used after washing, but can also be used after the use of a quik detail spray, or a waterless wash. The only requirement is that the surface is clean. Currently, all of Meguiar's Quik Waxes will not dry white on non painted exterior trim. Similar to our Quik Detail Sprays, they are mainly designed for paint, but will not damage any other surface.
        Hope this helps.
        Nick Winn
        Irvine, CA
        nawinn@meguiars.com
          Maybe am just lucky but none of the things from "Ultimate" serie have stained anything. Plastic, rubber you name it. Saved me ton of time detailing. So these are the products i'll keep using =)
