Do these headlights have a hard coating on them?
  • Do these headlights have a hard coating on them?
    Been sanding with 500 grit and it looks like there is some hard coating on them. Used up one disc already. Anybody else come across this?
    Re: Do these headlights have a hard coating on them?
    HMMMMM - Appears to possibly be the UV Coating from the factory that you have removed 100% in some portions and not 100% other sections ?
    If your goal is to remove completely, you will need to continue maybe even w/ 320 grit and then of course refine the sanding marks with several steps of finer grades of paper before polishing out and then coating.
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
      Not sure what that is but can't leave the sandblasted look the way it is. Drivers side came out smooth pretty easily, but this side is a pain.
        UGH....Keep persevering and you'll get it
        Mike Pennington
        Meguiar's, Inc.
        800-854-8073
          I've had several over the years that responded this way. Not sure why, but I agree with Mike, it's likely an original UV layer from the factory. My efforts with 600 grit were futile in most cases, but after refining with the other levels (800, 1000, 3000) it wasn't near as noticeable as it is at this stage.
            Got some 320 discs which made the job much quicker. Turned out fine.
              Glad to hear !
              Mike Pennington
              Meguiar's, Inc.
              800-854-8073
