Honda Fit with DA still getting small swirls after M205 VERY SOFT PAINT
  • Honda Fit with DA still getting small swirls after M205 VERY SOFT PAINT
    Hey peeps
    Just got the following products and decided to have a go at a very neglected paint.
    I started with just M105 but noticed it wasnt doing much work. So I did the following process wet stand 2000, M105 on agressive red pad (
    moderate pressure)> M205 on very soft black pad (VERY light pressure to no pressure). All applied via DA. What I noticed was that when I would clean everything off with IPA I would still see some swirls. Only thing that seemed to have removed swirls is going over it with Meguairs Carnauba liquid wax (forget exactly which one). I read that these Honda paints are VERY SOFT so thats why i tried to use as least of pressure as i could with soft pad and M205 but still couldnt get it looking completely perfect short of using a wax (i guess it fills in those swirls). I heard of people using M66 after M205 but I guess that essentially does the same thing (fills them in).
    I am wondering what can I try here as a FINAL step after M205 so when I strip all waxes off with IPA i get the glass look I get now after using carnauba wax!
    Pic BEFORE
    Pic AFTER wetsand 2000, M105 and M205 (still see some swirls)
    Pic AFTER wetsand 2000, M105 and M205, and carnauba wax (PERFECT)
    Re: Honda Fit with DA still getting small swirls after M205 VERY SOFT PAINT
    Welcome to Meguiar's Online. It's hard to tell from your pictures, but I am assuming you are referring to D/A Haze by your description of "small swirls left behind". There are two approaches here. You can likely get our M205 Ultra Finishing Polish to finish out haze free on a soft paint like you are working with, we did it for years, it just takes some special techniques. Here are a couple approaches to try:
    Try your same approach just using a very small amount of product.
    Another approach, is to ensure you pad has a good amount of product in it, and is fully primed & worked in, even run it on a panel for a pass, and then blow your pad out with compressed air, essentially backing out majority of the product in the pad, do not add any more product after blowing out, spray a very light mist of water on the section you are working on, and perform a very small pass. - I have done this many time to get soft black paint to finish out perfectly haze free.
    You might also experiment with a polishing pad like our Soft Buff D/A Foam Polishing Pad.
    Another approach is just to buy our new M210 Ultra Pro Finishing Polish! It's that simple, the product was designed for this situations, and makes "finish polishing" d/a haze sensitive paint easy.
    Hope this helps & let me know your thoughts!
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
      Thanks Nick, I already used very little compound but I will definetely try the water mist trick!
