Hyper Dressing or Endurance Tire Gell..
  • Hyper Dressing or Endurance Tire Gell..
    I've used Endurance Tire Gell and just tried Hyper Dressing..both sling even after sitting over night for at least 12 hours.. looking for thoughts..
    Re: Hyper Dressing or Endurance Tire Gell..
    We have found that preparation is just as important as application technique. Would recommend, if you have not tried already, to deep clean the tire sidewall several times with a product like our Non Acid Wheel & Tire Cleaner or M39 Heavy Duty Vinyl Cleaner, using a medium bristled nylon brush. From there, apply to the tire sidewall when the tire is completely dry. Use as much as needed for even coverage, and then allow to dry.
    Hope this helps.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
      Thanks for the info Nick.. I've used Purple Power and Awesome but I guess I've never actually deep cleaned them....I'll have to try the Non Acid Tire and Wheel Cleaner..
        You really want to spray, scrub, rinse repeat at least until there is no brown dripping off. I will do ever 2 - 3 weeks. Those products you listed should be fine, that said, our Non Acid does work very well.
        Nick Winn
        Irvine, CA
        nawinn@meguiars.com
          I guess I'll have to get a little more agressive with my cleaning process.. Thanks again Nick for the info..once Endurance Tire Gell is completely dry is it washable..
            In my opinion, I definitely like the Endurance Tire Gel better after having used both I find that the Hyper dressing just doesn't give as much of a gloss as the latter. But this is just how I feel if you want more information on how I use the gel feel free to check me out at https://valetdetails.com/.
              Hope this helps.
              I'll tip my buddy about deep cleaning of the tires before applying Endurance Gel. He never had satisfying results last time. He'll do some detailing after installing the suspension from 4Wheelonline this weekend.
