Endurance Tire Gell..
  • Endurance Tire Gell..
    Ok so here's my question..I've cleaned my tires with Non Acid Tire and Wheel Cleaner scrubbed them twice and applied 2 coats of Endurance Tire Gell..there was no brown on the tires and when I wiped my finger across the tire it was clean.. I'm assuming that sitting over night it will be dry in the morning..
    Re: Endurance Tire Gell..
    If there isn't too much product on the sidewall we do not anticipate you having an issue with sling.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
      Now the next time I wash it will I have to repeat the same process..
        Endurance gel takes a bit of time to dry, you don't need to put a lot on. 2 coats is way too much. Apply one coat sparingly and it'll be dry the next day. The less you use, the less gloss you get (I prefer low sheen). Almost sling-free this way. Been using it for years and years.
          It does take a while to dry.. I prefer high shine and I've always followed the directions and applied 1 coat and waited 10 minutes and applied a second coat..��*♂️
