D101 versus D149...when to use which?
  • D101 versus D149...when to use which?
    I have searched and searched to see if someone has posted this question before and came up empty. So, I have to assume that I should know the answer because everyone else does . Please, can someone tell me what the difference between the two are and when I should use either one? Thanks.
    Re: D101 versus D149...when to use which?
    D101 All Purpose Cleaner is a dedicated multi purpose cleaner with light to heavy cleaning ability depending on how it is diluted. Commonly used to clean carpets, cloth upholstery, several hard surfaces like colored plastic, rubber or vinyl materials on door panels, dashes & center console areas, as well as exterior trim. D149 Quik Interior Detailer is more for light cleaning & maintenance with added UV protection, but no real added gloss. Also D149 is safe to use on interior clear plastics.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
    CLICK HERE TO REGISTER AS A MEMBER FOR MEGUIAR'S ONLINE DISCUSSION FORUM
      Thank you Nick for the reply.
        can the green stuff be used as a pre wash ? spray it onto car let it stay for few minutes then rinse it off?
          Perhaps if diluted mild.. but I dont think it will have as much benefit as some of the newer pre wash products and sprays, that have the iron and tar removers in them.
