NXT Car Wash... have wax or cleaners in it?
  • NXT Car Wash... have wax or cleaners in it?
    Hey all,
    I use the NXT Car Wash (darn good stuff might i add) on my car all the time now...
    I just finally recieved my new custom exhaust for my bike. It's make of Ceramic that is polished to look like chrome... which they call Ceramikrome. In the paper i got with it, it says:
    Typical Maintence should only require washing with a mild soap and water. Occasional minor stains can be removed with a clean rag slightly damped (not wet or soaked) with gasoline and gental rubbing (do not scrub). ALSO TAKE CARE NOT TO ALLOW WAX TO CONTACT THE SURFACE OF THE PIPE as it can stain the pipe. MANY CAR WASH/CLEANERS contain waxes in them. Be sure to check the contents before allowing contact with the pipe.
    Can I use the NXT Car wash on my bike and around those pipes?
    Thanks all!
    If nobody on this forum can give you an answer, try some NXT on the pipes in a hiddin area and see what happens.
      mmm, the only hidden area i would be able to try is actually INSIDE the pipe before all the carbon starts to build-up. And i dont know if they polished it (or whatever they did) to the inside as they did the outside.
      these pipes actually shoot out from the engine of the bike, so you can actually see 360 degrees around the pipes. Hard to explain without a pic. i know...
        Re: NXT Car Wash... have wax or cleaners in it?
        Originally posted by integraoligist
        [B
        Thanks all! [/B]
        Yes.
        Also, try typing
        Ceramikrome
        Into our search engine...
          well for the past month i've just used a little NXT in a bucket, and just lightly went over the painted areas...
          Used the Chrome polish on all the chrome parts instead of washing them down with the car wash...
          And for the Ceramikrome pipes, I've used Aluminum/Mag polish (i heard it has lett abrasives in it then Chrome polish).
            And what have your results been?
              the chrome polish is nice, i havent attemped to take the bugs off of it from my last night ride yet... so they should be dried on there nice and hard by now, we'll see tomarrow.
              as for the mag polish, it worked great, i had a 3" section of yellow boot heel melted on it, after a little rubbing 99% of it came off, and i just picked the little pieces off with my fingernail.
              i'll take pic's asap and post them up.
