question about compounds, and swirl removers
  • question about compounds, and swirl removers
    first time posting here, so please bear with me.
    To remove swirls i use either the 3m perfect it 3000 or the 3m swirl remover and use the megs foam cuttin pad and polishing pad
    My question is, what would be the equivalent of using those 2 swirl removers
    thanks again
    If I recall correctly the Meguiars equivalent of those products would be #83 Dual Action Cleaner Polish and #82 Swirl Free Polish. You could also subsitue #82 with #80 for a bit wetter look.
    "Always do right - this will gratify some and astonish the rest."
    -Mark Twain.
      thanks, I think ill give those products a try.
      Are they cheaper then the 3m products?
      thanks
        also, one more quick question.
        IF i have wetsanding scratches from lets say 1200-2500grit sand paper, what kind of megs compound would i use?
        thanks
          thanks
          W-700(0/6) with #84 or W-4000 with #85.
          Rangerpowersports.com
          Ranger72
