Sometimes when I use my clay with detail spray I get streeks of clay left on the paint . This is even though a good layer of spray is put on paint. The clay is not brandnew but not very old. What am I doing wrong?
Detail Clay
Are you making sure that you buff the surface really well after the claying process?? I would say try going over those areas again with just the detail spray and then wiping dry to see if that might get rid of the marks. Just check your work with decent lighting to make sure you have gotten all the surface clear and buffed after claying.
*Also, don't forget to constantly "work" the clay so that you don't continue to use the same dirty clay surface*Trent W.
2002 Ford F-150 SuperCrew FX4
2002 Chevrolet Tahoe LS
Perhaps, your paints finish is not smooth and oxidized somewhat. I would think that if this was the case, your fighting with your clay. If your finish is in good condition, it may be just as Murr stated above. Are you putting enough detailing spray on? And, are you doing the claying in the shade on a cool surface?Brad
Detailing a Vehicle is very Therapeutic.
Even if you do get a smear, don't worry about it, just wipe off any residue with a microfiber... it happens during our Saturday classes as we have a lot of people claying usually with no or little experience.
Like I said though, if you do get a clay smear, don't worry about it just wipe it off with a microfiber...
from time to time I get a smear... like Mike P. said very easy to remove with a towel. The smears really show up on black.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
