Use pure water in your extractor. Spray APC on the area you want to clean, allow it to dwell a bit then scrub the area with a brush. Follow that with pure hot water in your extractor to rinse the fibers.
Are you using the APC in the extractor? Are you using the newer detail line APC or the older stuff.
If you are using the new stuff and not in your extractor, your mixing it with too high of a ratio (cleaner to water) or your appling too much to the area your cleaning.
