For most pickup trucks you can see the frame and easily in the wheel wells. So to make my truck's appearance a little better..I'm going to wash under the truck....mainly the wheel wells and the frame. I'm going to use tools that I don't use for the paint.
I will be using:
versa andgle body brush
nxt wash
3 1/2 gallon bucket ( not the 5 gallon ones w/ grit guards that I use for the paint)
My plan is to basically spray everything shown and get it all with the wash solution. Rinse it all off. Let dry by itself.
I would like your opinion on whether or not it's a good idea and what I should watch out for.. I have fog lights and the reverse sensing system w/ the pics of the wires. Any help and comments with be appreciated...Oh yeah..you will see the results as well. I plan on doing it today before the sun goes down.
Sorry this was the best I could do I don't know what's going on I set the size with easy thumbnails even and when I opened the pic up it showed up much larger and said the dimensions but once i uploaded them to meguiar's gallery it was small again. And the little box on the bottom right of the pic shows what happened when I used a dirty old mit and swiped the frame a little when I was doing the wheel wells and it turned out a lot cleaner looking.
I will be using:
nxt wash
