Polishing aluminium?
  • Polishing aluminium?
    Hello!
    I've seen on a swedish forum (I'll post the link later on) a guy who got kind of obsessed with polishing his car... He even went into the engine compartment!
    Anyway, it got me interested, if that guy could get so amazing results, well, I should be able to get some decent results... Even if I wouldn't have the best technique I would still put in a lot of effort and it should probably count for a lot!
    The only thing that has stopped me so far is the supply of the wax he's using, well he is actually using two of them...
    Is there any product that Meguiars has that can accomplish this kind of result? (I don't believe the metal polysh would quite do it, or am I wrong?)
    Here is the link, although in swedish you can probably enjoy looking at the pictures
    Amazing alu-polish
    /Marcus
    I do not think Meguiar's make bar metal polishes. A lot time, various steps and work went into the polishing the engine parts. I would not recommend this type of project to an amateur as first metal polsih project.
    Eric
    Talk it over folks. Communication is the key.
    --Jerry Springer
      Teak?
      On the other hand, what could go wrong? Even if an amateur did it and it was his first time, the only thing that could happen would be a halfway-great looking engine part? Compared to how it looks like from the beginning it shouldn't be a problem?
      /M
        Maybe www.superiorshine.biz can help you.
          Looks like this guy is really nuts.......
          What a difference! From casted metal to a chrome like finish.
          I'm a little worried about the endurance of this finish....
          Chrome is a brought on layer (attached to metal) wich won't rust.
          But when you polish the metal to this chrome like finish, there is nothing to protect it from oxidizing... and starting to rust?
          Am I wrong?
            Am I wrong?
            The metal will rust (oxidize) no matter if you leave it alone or polish it to be like chrome. But, if once the metal is polished, you put a protectant on it, like NXT All Metal Polysh or even a traditional paint sealant, the finish will be protected.
            In my opinion, a polished/smooth surface would be easier to prevent corrosion on since it should be harder for contaminates to adhere to a smooth surface, then again, *I* may be wrong.
            Don
            12/27/2015
            "Darth Camaro"
            2013 Camaro ... triple black
            323 hp V6, 6 speed manual
              Re: Polishing aluminium?
              Amazing alu-polish
              /Marcus
              I originally posted before looking at the picture, and you're right, the guy is crazy (but I must confess, If I had the time/money I would do the same thing )
              Seeing the pictures just reinforces my original opinion, it's easier to maintain than it is to repair. Now that he has everything highly polished, it will take minimal effort to keep it that way IE: regular washing with routine applications of a protective polish. I would prefer the NXT Metal Polysh since it would remove any beginnings of oxidation and leave a protective layer behind.
              PS: I did understand one thing in the thread...when he was told to "get a job."
              Don
              12/27/2015
              "Darth Camaro"
                The guy says the exact same thing later on in that thread... He claims that it is much easier to maintain a smooth surface...
                However, some parts that he knows will be difficult to maintain once they are mounted in the enginge compartment again are painted with a clear coat! The other parts he just used an ordinary long lasting LSP...
                I am very tempted :-)
                I just found the distributor for the waxes he is using, dunno the prices just quite yet...
                  Ok, the clearcoat thing seems very clever (when it's capable of high temperatures).
                  I'm intrested in how this parts look after a few months......
                  How long do these LSP's last?
                  Don,
                  If he hadn't done this the parts wouldn't have corroded I think since there was a sort of "coating" in the putts allready....
                  See:
                  But, the man has to get credit for such a Extreme Makeover!
                  (I wonder how he details his car...)
                    I have polished my aluminum calipers and Intake manifold on my Corvette. Also polished the AC compressor. I had the intake chromed after I got it polished. I bought 3M sanding rolls in different grids and used a die grinder then a high speed drill with a polishing buff and the bars of rouge. It is a time consuming job but looks awesome when done. I show my car and so no amount of work is too much if you want to win and I do. I don't know how to post them on here but I have pictures of the engine after I finished the polishing.
                    Black Bart
                      Black bart,
                      I´m curious how it looks... so maybe this topic will help you to put some pictures on the forum.
                      How to put pictures into your posts
                        What are your experiences with the surface later on? Will they corrode, problems with oxidation? Difficult to keep clean?
                        /Marcus
                          /Marcus
                          Depends on the quality of the aluminum and how well you expect it to look. I polished my rear brake calipers a year ago and have not done anything other than wash them since.
                          The Intake would dull and required polishing every few weeks so I had it chrome plated.
                          Chrome is far easier to keep looking good but in my opinion polished aluminum looks much better than just a sand casting.
                          If you decide to polish a sand casting be prepared to spend a lot of time getting it right but in the end it pays off. I have several BEST engine and BEST OF SHOW awards with my vette
                          Black Bart
                            Black bart,
                            I tried to post a picture don't know if it will.
                            Black Bart
                              Aluminum polishing
                              You might check this site too. I may try some polishing if a can brave the cold while my garage queen waits for summer.
