Do you think this machine can replace PC & Rotary (6" pads)
Combi tool.....what do you think........
I’d vote maybe.
I haven’t tried this particular one but I am a big fan of Bosch tools.
This tool looks like it might be a good alterative to the PC in countries where you can’t plug in a Porter-Cable.
I can’t see it replacing a rotary for serious work. It doesn’t have the power of many rotaries and the speed of driven eccentric polishers is usually slower than a standard rotary (not sure what the Bosch’s driven speed is, they only list the orbit mode speed in the specs). If you only need to use the driven mode once in a while and don’t mind if it removes defects slowly compared to normal rotaries it might be a reasonable substitute.
PC.
Originally posted by Jeff Smith
Not sure I would care too much for that black handle under the thing. I think I would be bumping and sliding that thing a little too often. Not much clearance there.
Seems when getting into tight spots it may be a little more difficult. Bu I am sure it is a good machine.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Actually I’ve been meaning to do that to my G100 too. Ya know the cast aluminum cover over the eccentric assembly? The one over the top of the backing plate? Well, it’s just at the right height to bash into low wings and deep air scoops on some cars. Not to mention the luggage rack cross bars on my truck.
So far I’ve had the presence of mind to wrap my fingers around the thing and let my knuckles take the hits instead of gouging the paint. But I think a layer of foam would be a wise addition.
PC.
Originally posted by the other pc
There are some other polishers out there with similar handles. I’d definitely wrap the thing with foam tape to avoid paint damage.
PC.Jeff Smith
Yep, lesson learned here. Did my first bit of sanding on a Bug Deflector on a '03 Silverado because of that. Fotunatley I corrected quickly. Made quite the neat noise.
Black ”handle” isn’t really a handle it’s for connecting the machine to a dust extractor and it can be removed in a second….
