Beat this shine on my latest detail - 40ft. motorhome
  • Beat this shine on my latest detail - 40ft. motorhome
    Using my meguiars pc, I started with number 83, then applied a coat of #80, and topped it all off with nxt! Beat that shine.
    Obessed with making it shine!
    Wow!
    Great job! I bet that took you a looooong time. How many hours did it take? What did you charge for it?
    Nice work!
    Chris
    Chris
    "Once a Meguiar's user...always a Meguiar's user!"
    1994 Accord
      Thanks Chris,
      This detail took almost 8 hours which meant no lunch for the wicked. I averaged about $45 an hour after expenses so you do the figuring. The only pain was the Texas heat which was 94 degrees with a heat index in the high 90's. Luckly the vehicle was in the shade. When I got done, I felt like my arms were going to drop off!
        Hey,
        Did you say 40 FEET????? Ugh!!!!!!! I own a 28' travel trailer and it takes me a good 1-2 days to detail it properly! But a 40 footer! That would be an eternity! I bet your shoulders and back are sore!!! If not.......they will be!
        Looks great!
          Not bad for a late 40's guy - let see some of you young bucks do the job and still hold your arms up. But I have to say OFF WITH YOUR HAT MEGUIARS - your products really rock and make my job easier!
            Looks Great! Check out the reflections, can't say that I have seen a motor coach look that good. I was about to do one (40ft coach) about a month ago and decided against it as I was unsure how long it would take. Now I know might have to take the job the next time. I guess the good thing all the surface is flat, I am sure you can buzz right along.
            Brandon
            2007 Black Chevy Avalanche
            My Albums: Avalanche
              Eight hours? Looks great!
              Wash, Dry, #83,#80, Nxt, remove/shine, windows, wheels and tires.
              Eight hours? I'd need two days, 16 hour!
              Great work!
              Jim
              If it was easy, everybody'd be doing it!
              www.jimmybuffit.com
                Awesome work Details3!
                The #83 followed by the NXT Tech Wax is a great combination for a 2-step system, especially when working on large rigs like this one.
                I've only buffed out one 40' motorhome in my life and after I finished that one I said, [b]"Never again". By the way, when I did my motorhome I had to do it by hand with some #6 because the Porter Cable had not yet been introduced to the paint polishing world yet! Talk about some tired arms! Also it was a motorhome with an oxidized fiberglas gel-coat finish... ouch! I only wanted to do a one-step process and I didn't want to use the rotary buffer on it...
                Good job!
                  Hey car crazy - even though the service is flat, there are a lot of little areas. Buzzing along was not too bad at the start, but by half way through the second coat I was feeling the pain! I will admitt - sleep was nil that night as I was dreaming:
                  I was detailing the rv and when I got done with each pass it disappeared - so I detailed it again, and again, and again - all night long!!!
                    It only took you 8 hours?!? What's your secret in doing it so fast man? Anyway, great work! It just looks so shiny and slick! I admire your work man!
                      Thanks,I did a three coat process of #83, then #80, and finally NXT. The #80 really brings out the shine after the #83 and topping it off with NXT blows it out the window. Since the motorhome is only a year old, that helps in being able to do it so fast. Then again, experience tells you how to work the shine depending on color.
                        D3,
                        I think you have cornered the large vehicle detail market in Dallas with the semi and now a 40' RV. Great work on the RV.
                        Eric
                        Talk it over folks. Communication is the key.
                        --Jerry Springer
                          44' coach!
                          No full shots of it though, by the time I and my son finished, it was storming pretty bad outside. The rolling staircase sure made the work easier.
                          Do you regularly do RVs? That coach is really the only thing that size I do any more. They just take up too much time.
                          Owner, Scott's Mobile Auto Detailing
                            Hey Scott,
                            Looking at your shirt in the picture, I would say that the roof above your head had a pretty bad leak!! LOL!!!
                            That picture of the 44 footer still amazes me!
                              The only RVs I do are the coaches as most owners of my bigger boats also have a big RV coach. Scott, your shirt looked like mine - I had the same leak
