While detailing a customer's vehicle today I learned something that I had never tried before. The customer had sap on his hood and trunk and he asked me would I be able to remove it. Of course I told him yes. He asked had I ever used Rain-X to remove sap from the paint (and of course I hadn't). He suggested I try it to see how it works and offered to retrieve some from his garage. I told him that wouldn't be necessary because I had some readily available. To make a long story short - I put some Rain-X on one section of a MF towel, dabbed the sap with it for a couple of seconds or so - and to my surprise the sap came off as if I it was jam. Simply amazing I thought. Caution - it mitht remove a little wax, but I hadn't waxed the car yet so that was no problem. Even so, in my opinion it didn't remove any previous wax at all. I guess you never get too old to learn something new that really works. I just wanted to share this info with you guys.
Another Use For Rain-X
Re: Another Use For Rain-X
Very interesting... was it the original or the wax type?Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Looks like its mostly Ethanol/SD Alcohol 40? Is that right?Brandon
Nearly every ingredient in the mix is a solvent which would explain the 3 on the NFPA matrix. Also, the types of solvents involved would suggest to me that it will, indeed, remove wax and, for that case, probably all of it where ever the RainX product comes in contact with a 'waxxed' surface.
Be careful using alcohol. I know someone who used it to remove tape residue (wedding flowers) from the black b-pillar and it stained it a bit. I removed the staining with ScratchX. Maybe the alcohol just cleaned the area very well and that is what caused the change in appearance. But I still worry that alcohol isn't the best thing for cars....
Course, alcohol's not the only option for tree sap.r. b.
Petrolleum Distillates work, WD-40 if you like a greesy film, 3M Tar and Adhesive, and water are effective on tree sap. You can soak it with a towel to loosen it up.
Here is a thought:
Hot water i.e. you paint is baked at hundreds of degreese and on a hot day is often over 200.
You can probalby pour some hot water on it without problem and it should melt.
Just don't cause your metal to warp by expansion caused by uneven heat.
I still say spray it with Bug and Tar remover and wait 30 seconds to 1 minute then wipe it off.
Originally posted by Rusty Bumper
I believe your story, but the one of the pro's on this board has used it many times with good success.
I think that is the Washer Additive. Here's the actual spray: http://hpd.nlm.nih.gov/cgi-bin/house...ds&id=19037001
