I've used the 3M Headlight coating on over a dozen headlights over the years with excellent results and without any problems until yesterday. I prep them with 500 paper dry in a drill, followed by 1,000 and 3,000 Trizact discs wet. Then wipe on the coating. After it dried there were cloudy streaks all over the the headlight as if it didn't flow smooth after application. Could this be caused by the low temperature when I put it on? It was 42
First time issue with headlight coating of another brand
Re: First time issue with headlight coating of another brand
Forum cutting off my posts after I had the small "0" degree symbol after 42. Weird.
I've used the 3M Headlight coating on over a dozen headlights over the years with excellent results and without any problems until yesterday. I prep them with 500 paper dry in a drill, followed by 1,000 and 3,000 Trizact discs wet. Then wipe on the coating. After it dried there were cloudy streaks all over the the headlight as if it didn't flow smooth after application. Could this be caused by the low temperature when I put it on? It was 42F while in the past it was over 60 when I used it. How to remove and start over? M105 compound? Does the Meguiar's spray coating have a minimum temperature for application? Does it need a polishing step before applying or can it be put on after the 3,000 disc?
Originally posted by atikovi View PostForum cutting off my posts after I had the small "0" degree symbol after 42. Weird.
I've used the 3M Headlight coating on over a dozen headlights over the years with excellent results and without any problems until yesterday. I prep them with 500 paper dry in a drill, followed by 1,000 and 3,000 Trizact discs wet. Then wipe on the coating. After it dried there were cloudy streaks all over the the headlight as if it didn 't flow smooth after application. Could this be caused by the low temperature when I put it on? It was 42F while in the past it was over 60 when I used it. How to remove and start over? M105 compound? Does the Meguiar's spray coating have a minimum temperature for application? Does it need a polishing step before applying or can it be put on after the 3,000 disc?
And yes temperature can absolutely make a difference. Recommended minimum for Meguiar's is 55 degrees Fahrenheit.Nick Winn
Irvine, CA
nawinn@meguiars.com
