Is my wet/dry vac strong enough to extract?
  • Is my wet/dry vac strong enough to extract?
    I have a craftsman 2 gallon 1.5 hp portable vac. Is the 1.5 hp strong enough to extract liquid from carpet?
    Here is what i want to do:
    Spray APC+
    Scrub with brush
    Extract with shop vac
    Re: Is my wet/dry vac strong enough to extract?
    Spray APC+
    Scrub with brush
    I'm sure it has more lift than the LGM, and a lot of members use one of those.
    I follow my LGM with my vet-vac, but it's a 6.5hp I think.
    Rasky's Auto Detailing
      I think the argument against the shopvac is that the chemicals that are being lifted up aren't good for. I have no idea if it's true or not though.
        My shop vac is 6hp and I have a spot remover extractor with upholstery nozzle.
        Shop vac would be fine!
          Shop vac will work fine, I have used one for years.The key is not to soak the carpet all that will do is drive the dirt down to later reaper after it dries.
          Vac thoroughly,pre-treat stains with APC , have small bucket with very hot water just deep enough to cover the bristles of the brush, lightly spray 12 x 12 area with APC ,dip brush in hot water and shake out, scrub area, use just the end of the hose no nozels **** up the suds and water , go over several times than take a clean towel and go over area turning towel, that will pull remaining dirt from carpet and help dry.By looking at towel you will see the dirt, when the towel just looks wet and not dirty your done.
            Follow Shyneman's advice and use as little fluid as possible to do the job and just about any vacuum would work.
              No problem using a shop vac. It will have enough lift.
                Just thought that 1.5 hp was on the weak side
