Just scored for FREE a LIKE NEW small extractor!
I was working a jobsite today where they were remodeling a bunch of storage rooms....they had a pile of commercial cleaning stuff they were throwing out...most of it was old junk..then I saw the little machine sitting their...ask the guys if I could dumpster dive and they said GO FOR IT!!!! SO I DID!!
Here are some specs off the companies website:
Anserâ„¢ Spotter Extractor
Spot clean a variety of soft surfaces with the portable Anserâ„¢ Spotter Extractor
Unit is like brand new..may have only been used once....got it home...wiped it down and fired it up...works flawlessly!!!
I'm going back tomorrow to see what else I can find!
Here is a picture of the unit (mfg. photo)
- Perfect for small stains and soil concentrations
- Easy to transport at only 18 lb / 8.2 kg
- Recovers water easily with the 1.12 hp / .84 kW vacuum motor
- 2 gal / 8 L solution tank; 1.5 gal / 5.7 L recovery tank
- 1.12 hp / 0.84 kW, 2-stage vacuum motor
- 120-volt solution pump; 30 psi pump pressure
- 8 ft / 2.4 m vacuum and solution hoses
- Durable, corrosion-proof polyethylene construction
- 25 ft / 8 m power cord
- 4 in / 102 mm clear hand tool
- 8 ft / 2.4 m vacuum hose
- 8 ft / 2.4 m solution hose
