microfiber pads
  • microfiber pads
    anyone make a good microfiber pad rather than bonnet over 7006
    Re: microfiber pads
    bump anyone
      Re: microfiber pads
      Don't know of any...
      You kind of want a microfiber bonnet over a foam pad because the foam gives you cushion.
      Then you can take the bonnet off and use the other side and/or wash it for the next time.
        Re: microfiber pads
        thanks
        i have 6 inch bonnets from ads that are just too tight for a 7006 imo
        its a pitb
        i was thinking of buying 6.5 inch bonnets instead? too lose?
        also whats a decent 5.5 , 4 inch pad for the g110 and included backing plate?
        thanks for hooking me into this detailing thing
        i keep staring at everyones paint on their cars for swirls..
          Re: microfiber pads
          I have some of the old Meguiar's bonnets and putting them over the foam pad is tight. It's sort of a pain. If it was lose I think it wouldn't be as effective.
          Scott
            Re: microfiber pads
            I have all three sizes of Meguiar's Ultimate Bonnets...
            6.5", 8". and 11". Plus, I have some of the gold Class bonnets, but I'll have to check those sizes.
            What is the actual pad diameter you're using?
            Are you hoping to apply or remove product with the bonnets?
            Are you using them for abrasives, polishes, or waxes?
            Kevin Brown
            NXTti Instructor, Meguiar's/Ford SEMA Team, Meguiar's Distributor/Retailer
              Re: microfiber pads
              just for wax /cleaner wax removal
              ads sells 6 inch bonnets for use on a 6.5 7006 pad
              i think its not a very good fit
              a half inch is quite a bit when trying to wrestle a bonnet on a pad ,just a hassle id rather not deal with imo..
              i am looking for a better fit with a 6.5 bonnet rather than 6
              this is for wax removal only
              or just a good microfiber pad in itself ,velcro on/off ..daydreaming i gues
              is a 6.5 bonnet on a 6.5 pad gonna be that loose?
              thanks for all your replies!
