Hi all
Ive searched and found a little info but id just like some clarification. Im learning to use my new g220 on my 90 mx-5 that is single stage red. im at work ATM so i dont have 100% details on polishs im using but on my test spot i found it needed to use a polish ( arround number 7 on the meg's scale) on a polishing pad and then finishing with number 9 swirl remover on a finishing pad. now the second step is removing the hazing but its leaving little scratches almost like "C"s or "?"s. After some reading i found that it might be becuase of my pads not being clean enough. i re cleaned my finishing pad and tried again but with the same results. im doing 2 passes with mild pressure at speed 6 and then 2 passes on speed 4 with little pressure. Any tips would be great thanks.
p.s ive read and rea read the hot topics etc but havent found anything on this
Reguards
Scott
Reguards
Scott
