OPM speed settings for the DA polisher?
This is a sticky topic.
  • OPM speed settings for the DA polisher?
    Does any know the OPM speed settings of these three DA polishers?
    I'm really looking for the speeds 3800 and 4800 to use D300 and D301
    Meguiar's G110V2
    Griot's Garage 6"
    Porter Cable PC7242xp
    Merlin
    https://AMiracleDetailing.com
    Facebook - YouTube - X - Instagram​​
    Re: OPM speed settings for the DA polisher?
    Here's G110v2:
    • Speed Setting 1 - 1800 opm
    • Speed Setting 2 - 2800 opm
    • Speed Setting 3 - 3800 opm
    • Speed Setting 4 - 4800 opm
    • Speed Setting 5 - 5800 opm
    • Speed Setting 6 - 6800 opm
    I don't have manuals for neither Porter Cable nor Griot's Garage tools. On their web pages only ranges are listed: 2,500 - 6,800 opm:
    Car Care for the Perfectionist! Polishes, waxes, cleaners, polishers, foaming systems, detailing supplies, and accessories. We make it, we guarantee it!
    Probably speed 4 for D300 and speed 3 for D301 would be still accurate.
      Here are the OPM's for Meguiar's G110v2 Speed Settings:
      Use Speed 4 for D300 and Speed 3 for D301.
      Nick Winn
      Irvine, CA
      nawinn@meguiars.com
        Well after some research here's what I found.
        OPM's for G100/PC
        Speed Setting 1 - 2300 opm
        Speed Setting 2 - 2350 opm
        Speed Setting 3 - 2600 opm
        Speed Setting 4 - 3280 opm
        Speed Setting 5 - 4780 opm
        Speed Setting 6 - 6100 opm
        Speed Setting 1 - 2560 opm
        Speed Setting 2 - 3250 opm
        Speed Setting 3 - 3950 opm
        Speed Setting 4 - 4600 opm
        Speed Setting 5 - 5550 opm
        Speed Setting 6 - 6700 opm
        OPM's for Meguiar's G220
        Speed Setting 1 - 2760 opm
        Speed Setting 2 - 3450 opm
        Speed Setting 3 - 4150 opm
        Speed Setting 5 - 5750 opm
        Speed Setting 6 - 6900 opm
        OPM's for UD Machine
        Speed Setting 1 - 2660 opm
        Speed Setting 2 - 3950 opm
        Speed Setting 3 - 4130 opm
        Speed Setting 4 - 4900 opm
        Speed Setting 5 - 5240 opm
        Speed Setting 6 - 6540 opm
        OPM's for Griots 6"
        Speed Setting 1 - 2500 opm
        Speed Setting 2 - 3300 opm
        Speed Setting 3 - 4200 opm
        Speed Setting 4 - 5100 opm
        Speed Setting 5 - 6000 opm
        OPM's for PC7424XP
        Speed Setting 3 - 4000 opm
        Don't take it for gospel and if there are any changes please reply.
        Merlin
          Thanks for posting this Merlin!!!
          I Meguiar's agrees with the info above I think it would be nice to see this as a STICKY!
          Rasky's Auto Detailing
            +1
            and maybe we could add Flex XC 3401 VRG DA as well.
            Setting 1 - 160 rpm (3,200 opm),
            Setting 2 - 200 rpm (4,000 opm),
            Setting 3 - 270 rpm (5,600 opm),
            Setting 4 - 330 rpm (6,600 opm),
            Setting 5 - 400 rpm (8,000 opm),
            Setting 6 - 480 rpm (9,600 opm).
              Do the OPM's change for each of the settings for the first generation PC 7424? Thank you.
                How about the Griot's 3" polisher...anybody have the OPM specs?
                  I got my answer from CSR at Griot's
                  1: 3,500 OPM, 2: 4,800 OPM, 3: 6,100 OPM 4: 7,400 5: 8,700 OPM 6: 10,000 OPM. These speeds are all approximate and depend on how much force is applied to the pad while the machine is orbiting.
                  Sounds like the very low settings are needed to stay within MF DA specs
                    Thanks Guys!
                    Got all the nfo (and more) than I expected. Right on!
                    Now I have no excuses not to make the job absolutely perfect.
                      Originally posted by xuyuan88st
                      M105 with a DA will do the job but it's a little finicky to work with. I put a little UC on the pad along with a little M105 and it gets the job done.
                      I have found a similar but different combo I use...two dime size drops of D300 with two dime size drops of M105.
                      Great cut, much long working time and no drying or mess.
                      Merlin
                        This post should be a sticky. I was going to use my 5" microfiber system for the first time today. I could not find RPM speed on my 7242.
                          (thread bump)
                          I've searched, but just can't seem to find a clear definition of "opm", as it relates to the rpm of the machine. What EXACTLY does "opm" mean? My DA, which is a very low end sander (400W, 5mm throw, with a backing plate a bit under 5") from a hardware store, has a no load RPM range of 4500 to 13000. The specs also give the no load "oscillation rate", which is 9000 - 26000, which is obviously exactly double the RPM. So, if we simplify it and assume that the pad is stalled (no free rotation), the whole pad is rotating around the forced-rotation axis at between 4500 to 13000 rpm, and if we consider each semi-circle of these rotations as an "oscillation", is that why it's exactly double?
                            As I recall, OPM means orbits per minute, like RPM means revolutions per minute. I think you're being generous calling your sander a DA; different machines for different uses. Here are some links that may be helpful in discussing speeds:
                            General Auto Detailing Discussion. Participate in existing discussion or start a new thread with your question.
                            Originally Posted by Tom Weed I was using too much product after cleaning each section. Even with 3 pea sized drops?
                              Thanks Joe. So, what is an "orbit"? Is that one revolution of the pad around the forced rotation spindle?
