So for the first time in months, I finally had some time tonight to clean up the car and attempt to do some work to get swirls and scratches out of my paint.
About an hour in using the cutting pad from microfiber system, the G110V2 just stopped working. At first, I thought the plug had come loose from the outlet or the unit had overheated, but that wasn't the case at all. After fiddling with it for a few minutes, it seems that the problem is where the cable meets the unit. If I applied HEAVY pressure on the cord and pushed it into the unit, it would fire back up, but only if I held the pressure.
I checked my receipts and it turns out I bought the G110V2 from Auto Detailing Solutions on 4/29/11, so my 1 year warranty ended last month.
Has anyone seen this before? Is there anything I can do? I have used the unit maybe 4-5 times prior to this, I don't use it very often. The unit is never abused and is always stored properly in the Meguiars tote bag it came with. I'm devastated because not only can I not finish my detail tonight, but I'm out of a dual action now.
