Hello,
I finally tried my G-100 out this past weekend. And it was an interesting experience. My car was in an accident lastyear and most of it was repainted. However they did leave alot of swirls in my finish. I tried #80 yesterday and it did an ok job. I mean im not exactly sure if im using it properly. I always applied it on the pad in the "x" shape, and i always made sure i would apply 20 lbs of pressure to the back of the g-100. I buffed it till it was hazy. Then wiped it off with a simoniz terry cloth first, and then the ultimate wipe after. The finish was definately cleaner, and when i looked at it under the garage light it was beautiful. However the moment i brought it out into the sun i noticed that i could still see swirl marks. The swirls are not as bad, but they were still definately there. I then covered it up with NXT Tech wax, and it made it all go away. Howver i know that sooner or later they'll once again be visible. Im not really too worried about it till summer time, since i only really wanted to lay down a new layer of wax before winter time came.
I also wanted to make sure that i have the right idea with the pads.
After i used the pads i stored them in a ziplock opened in a cabinet. I didnt clean them off, i just stuck them in the bag. I just read a few minutes ago that before usage i should clean them off with a soft nylon brush. Do i have the right idea here?
Any help would be great. Thank you
