what the gray noe on the G100A?
  • what the gray noe on the G100A?
    i can not find G100A or PC in my country.
    so i found some similar ones.
    but i can not see the gray one on the G100A(just between pad
    and body)
    will it do anything if i don't have this.
    That "grey " thing between the backing plate and the main unit is what gives the unit a orbital effect, without it it would be like a rotary polisher. It is a off center weight, some units are 5" and others are 6".
      Re: what the gray noe on the G100A?
      and body)
      The G100 is basically a wood sander with a foam pad on it for polishing paint. There are a zillion orbital, electrical sanders on the market and some folks are able to attach a foam pad onto them to polish paint.
      To date, most of them do not offer the power the G100/PC offers and most of what people post about their experience is they are unable to remove defects like swirls and scratches.
        Re: Re: what the gray noe on the G100A?
        without the gray thing still i can do well job ?
        one of the product (RYOBI) said that
        1 .600-2000 rpm
        2. output 910w
        3. 7"
        4. weight 1.8kg
        does it enough ?
        i live in taiwan. i do not have many choices.
        and i do not know how to buy G100/PC.
          You can also look for a Porter Cable 7424, it is the same as the G100 but does not have a life time warranty.
            Re: Re: Re: what the gray noe on the G100A?
            1 .600-2000 rpm
            2. output 910w
            3. 7"
            4. weight 1.8kg
            does it enough ?
            What you showed is a rotary buffer. Simply put, a rotary buffer only turns round and round. There should be lots of them in Taiwan if that's what you're looking for, as that's where a lot of the non-namebrand ones are made.
            Like Mike suggested, any random orbital sander would work, but most are not as powerful. The highest I've seen is one of Dewalt's sanders, rated @ 3.0amp / 360w (versus 3.7amp / 444w for PC).
              Buy online?
              BLINK Detailing
              Serving the GTA Area
