Meguiar's Clear Plastic Products
Here is the complete collection of products Meguiar's offers for working with clear plastics both by hand and machine.
Mirror Glaze Clear Plastic Polish
The finishing touch for maximum clarity and brilliance. Meguiar’s Plastic Polish provides the second step in our two-step restoration process for clear plastics. One easy application protects surfaces previously cleaned with our M-1708 Plastic Cleaner. You will reveal the materials natural brilliance, while leaving behind an anti-static coating that helps repel damaging dust and dirt.
Mirror Glaze Clear Plastic Cleaner
Safely removes hairline scratches, dirt and grime. Clear plastic that has lost its clarity due to significant contamination and fine scratches should be treated using our two-step process. Meguiar’s non-abrasive, alcohol-free Plastic Cleaner aggressively cleans and removes scratches without harming the surface. Follow up with our M-1008 Plastic Polish for a perfect finish.
Mirror Glaze Clear Plastic Detailer
A single-step solution that keeps clear plastic surfaces pristine. Regain the original crystalline clarity of plastic in need of restoration, using this convenient all-in-one product specially formulated by Meguiar’s. Simply spray it on and wipe it dry. You will safely remove surface contamination and achieve dramatic results on everything from window panels and instrument lenses to eyeglasses, CD's and picture frames.
PlastX
This easy to use, rich gel formula quickly restores optical clarity to both rigid and flexible plastics. Cutting-edge advancements in Meguiar's exclusive Microscopic Diminishing Abrasive Technology, (MDAT), removes light oxidation, chemical degradation, surface contamination, stains and light surface scratches with ease. In addition, because our microscopic diminishing abrasives breakdown as you use them, PlastX Clear Plastic Cleaner & Polish is safe on plastic rear windows on convertible tops, aircraft windows, motorcycle fairings, face shields, headlights and taillights, instrument panels, all clear plastic boat surfaces and aquariums. Meguiar's PlastX also contains highly water-resistant polymers. These specialized hi-tech polymers provide long lasting durable protection to keep your clear plastics clear and beautiful longer. PlastX is non-toxic and does not contain any harsh solvents.
Meguiar's teaches the philosophy of using the least aggressive product to get the job done. We also teach that surfaces, in this case clear plastic, need to be maintained. Maintaining a surface is an ongoing process, not a one time procedure. Thus in order of aggressiveness...
M10 Plastic Polish - Completely non-aggressive. This is a pure polish that is formulated to restore optical clarity and maintain clear plastic surfaces. M10 Plastic Polish should be used on plastic surfaces in excellent shape to maintain them, and/or after a neglected plastic surface has been pre-cleaned using a dedicated plastic cleaner such as M17 Plastic Cleaner, or PlastX. M10 Plastic polish leaves behind an anti-static surface.
M17 Plastic Cleaner - M17 is a light cleaning polish for clear plastics, it is non-abrasive and and perfect for removing stains, light oxidation and other contaminants off the surface. It can remove very light scratches out of soft plastics when worked thoroughly but gently against the surface. After cleaning with PlastX, for maximum optical clarity and to leave an anti-static finish, apply M10 Plastic Polish.
PlastX - PlastX is a unique plastic cleaner in that it contains a special microscopic diminishing abrasive that enables it to actually remove below surface scratches by removing small particles of plastic surrounding the scratches. After cleaning with PlastX, for maximum optical clarity and to leave an anti-static finish, apply M10 Plastic Polish.
Besides your choice of product, your choice of applicator material can also effect the aggressiveness or gentleness of a product. Meguiar's Hi-Tech Foam Wax applicators are a good choice for gentle cleaning and polishing. For more aggressive cleaning and polishing, try using a material with a nap such as 100% cotton toweling, or our Even Coat Applicators made out of microfiber.
Because clear plastic surfaces tend to be scratch-sensitive, remember that not only is your choice of product and applicator material important, but just as important is the quality and type of removal material, in other words, your wipe-off clothes or towels. For clear plastic surfaces, always use a premium quality microfiber polishing cloth, or a clean, soft 100% cotton terry cloth towel. Inspect your wiping-cloth before using to insure it is clean and free from contaminants and anything that cold instill a scratch into the plastic surface.
When working on plastic surfaces for the first time, and whenever you use a product for the first time, it's always a good idea to test the product, your applicator material and your application process, (In this case your hand and your skill level), in an inconspicuous area. If you cannot make a small area look good with your product, applicator and process, you will not be able to make the entire surface look good, so test first to be an the safe side.
PlastX
