What's Unique About Meguiar's Professional Beyond Ceramic Paint Coating M888?
  • What's Unique About Meguiar's Professional Beyond Ceramic Paint Coating M888?
    It's everything you've come to expect from a professional ceramic coating and more. Meguiar's M888 – Beyond Ceramic Paint Coating has 100% active ingredients and is a little thicker formula than a traditional coating. This is why we specially engineered the unique microfiber applicator to allow you to spread the ceramic paint coating evenly into the paint. On average, you want the coating to sit on the paint for about 2-5 minutes before wiping it off. However, it can sit longer and will still come off easily. Even as much as 24 hours later, high spots can still be fixed by simply applying fresh product and wiping it off. Initial curing takes about 24 hours, and full curing takes about a week when you can then use chemicals and car washes on the paint. M888 is also effective on other surfaces, including PPF, vinyl, trim, plastic, painted and OEM wheels, etc. It's also a single-layer coating, so you don't have to apply multiple coats to get the full protection and benefits of the coating, including ease of wipe-off. For the car ceramic coating to bond properly and maximize performance, it's recommended to clay and decontaminate the paint before applying. If you want the paint to look as good as possible, include a full paint correction. After applying, M888 will darken the paint and conceal some minor defects rather than highlight them. The best way to maximize the protection is to wash and clean the surface regularly. Professional Hybrid Ceramic Bead Booster M799 is the perfect companion product for M888 to help enhance the coating. Note, M799 is not required.
    Intro –
    0.00 Beyond Ceramic Definition
    1:07 Application & Removal
    4:12 Wipe off Demo #1
    7:30 Curing Time
    8:26 Alternative Surfaces
    12:00 Prepping the Paint
    15:00 Maintaining M888
    21:10 Conclusion
    26:17 Wipe off Demo #2
    27:03 Referenced Video: M888 Installation Guide - https://s.meguiars.com/l01372dy
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
