How do you get a slide show into your avatar? I have several pics of my favorite character (Ed) that I'd like to display & I can't figure out how.
slide show avatar?
Re: slide show avatar?
I am aware of a couple of ways.
Nappers I believe purchased photo shop and one of the applications makes the slide show.
Ryan L. Went to picasion.com.
I tried this one out. It worked very well. The instructions were easy to follow. On this the max size is 160x210 pixels. After you put your images in, click submit paste the url into your Avatar.quality creates its own demand
While the original post is a bit old, I thought I'd answer for any others that might have the same query.
The 'slide show' you're desiring is called an animated GIF, you have to crop & resize all the images to the same size allowed for avatars, then you create an animation in Photoshop, there may be other applications but Photoshop is the one I've used. Of course you have to limit the number of "slides' and/or the size of the avatar because of the 58.6k limitation on avatars.
Patrick
Originally posted by PCC View PostWhile the original post is a bit old, I thought I'd answer for any others that might have the same query.
Patrick
RyanAttack life, it's going to kill you anyway.
