How To Use PhotoShop Elements to Create Animated Avatars
  • How To Use PhotoShop Elements to Create Animated Avatars
    Gang,
    here is a tutorial how to make an animated avatar using Photoshop Elements. I currently have Elements 4.0 but the procedure should ring a bell in other versions as well as the full PhotoShop program. PS Elements can be found at most retail stores, my wife got mine at Costco for like 60-70 bucks and it's a great program if you like to work with photos.
    Follow along and if something doesn't work, please let me know via PM and I'll send the correction to a Mod and it will be fixed.
    I tend to do my tutorials (I do a lot for work) if you did not know anything about nothing. For dummies if you will
    Let me know how you like it.
    Photoshop Elements: Click the Edit and enhance photos button
    This is what you get.
    Open a new blank file:
    Set the size of your avatar: The max for MeguiarsOnline.com is 160 X 220 and 6000 maximum kilobytes.
    I leave the resolution alone (or haven't messed with the settings to see what it does yet anyway). I leave the background as white and use the fill as needed. And yeah, name your project.....
    This is what you start with:
    Some tools you will use. Text, Crop, Fill (like bucket in paint), and the color box. The color on top is the main color, the color below is a background color. I don't mess with the bottom color.....
    When you click on color this is what you get:
    My first layer will be text, click the text button and make a box, yada yada yada. The background will be white and you can fill it later if you like. Change the color of text, font etc. If you "right click" on the text box you can have other options to have warped text, fish shaped etc. Lots of options. Just remember the fancier the avatar, the larger the file.
    I'm going to use a picture next, >File >Place, you know where your pictures are and select one. Each time you use the Place, it makes a new layer. Copy anything makes a new layer too. Using place to add photos places the photo within the size of your project !
    See I chose 3 pictures and my text layer. Put the layers in order, the original layer will be first and you just drag and drop. If you notice from my earlier pictures that I deleted the "background" layer. You can delete layers easily by right click and delete.
    If you notice the "eyeball" looking thing next to the layers. You can turn off individual layers to make sure they look alright then turn them back on. Leave one layer on at a time to make sure your work is okay. bummer to save it all and have something amiss!
    Now the fun part, click >File >Save for Web:
    Check the boxes indicated and do a run through manually and make changes in order of layers as needed or whatever(after hitting cancel of course), if you made changes, click file>save for web and come back here:
    When you click okay, it will save as a .gif, name your file and save it where YOU WILL REMEMBER.....I forget a lot where I put stuff
    Make sure your file is below the maximum size and upload your avatar in your USER CP (CP=Control Panel, making sure your logged on of course)
    Ta da:
    Happy Avataring
    Aaron
    Re: Photoshop Elements to make animated avatars
    Sorry to burst your bubble. But you can just go to http://picasion.com/ and put your images in. Click submit and paste the URL into your Avatar.
    Takes about 30 seconds.
    Cool stuff though.
    Ryan
      Great Write Up!!
      I'm sure this will help all of members out!!
        Cool stuff though.
        Ryan
        I think even I could handle this. lol Thanks, Guys.
          Cool stuff though.
          Ryan
          You didn't burst my bubble.
          I was told about picasion but it gave limits and I was asked to make a tutorial with using PS Elements which is how I made mine.....
            That flashing avatar is distracting!!
              They can be.
              I had one where I put flasher bursts on my cars using PS Elements and they alternated between cars and it was a little much so I didn't use it.
              I was going to put subliminal messages in it so everyone sends me a dollar.
                Great write up Aaron!
                  They can be.
                  If it works and they send you a dollar, Make me one.
                    I'll make one up and see what happens
                      Thank you Aaron for creating this.
                      I really like your current animated Avatar because it's like a little educational slide show in all your posts.
                      Nice work!
                      I have Photoshop Elements 2.0 as it came with my Rebel camera, when I get a chance I follow your tutorial and see if I can create something similar.
                      Office: 800-869-3011 x206
                      Mike.Phillips@Autogeek.net
                        Well I just tried Ryan's way at picasion.com. I told you it must be easy if I could do it.
                          Theres another speed that isn't so fast...a little less flashy.
                          But looks good!
                          Ryan
                            Re: How To Use PhotoShop Elements to Create Animated Avatars
                            I do like your website, but in the event the site goes down, so does your avatar..... Unless you saved it
                            I like using PS so you can position objects or do the text like I did.
                            Picasion is a good source though and easy
                              I thought of changing it up once in a while
                              Hopefully they are not too different and you can do the animated .gif's
                              It's been fun so far.
                              Elements is also great for photo editing for your digital pictures, I've messed the hair up on some co-workers here at the jail and they just love me
                              "DO NOT GIVE BELKNAP A DIGITAL PHOTO OF US!"
