Making Blue Clickable Links for Dummies
Gang,
I've seen it come up a few times but we would like to change the color we add links to.
Here's a how to for dummies!
As usual, if something don't seem to work, send me a PM and I'll see if a Moderator can fix it for me.
First: Figure out what your title of your words are. In this case, I'm going to write out Meguiar's and put a link on that.
Highlight your title as you normally would: You need to highlight to add link, change color or bold, center text etc.
You need your URL link, unless you know it.....In this case, I opened a new tab in Internet Explorer and opened the Meguiar's site. Highlight the address and right click and copy.
Push the insert link button as shown:
You will get a window to insert your URL:
The http:// should already be highlighted, either insert your URL or when I copied the Meguiar's address earlier, I'm just going to right click and paste. You keyboard people (like me) can hit CTRL V and paste your link. Be sure to make sure you don't have two "http://" in your link, I've done that a few times and the link did not work.
This will add the code for the link. The words Meguiar's are still highlighted as you see:
As the words are still highlighted, simply change your color and Bold if you want to:
See how the code is inserted? For the color to change, it has to be entered after the link code. The code on end of your title are the closing or end codes (can't remember the name) but they end what command they do, [/b], [/color], [/url], see?.
Bold.....See how the code is inserted?
When you post your thread, it should look like this!
Any problems, let me know!
Aaron
Gang,
Aaron
