Endurance Tire Black
  • Endurance Tire Black
    How is the best way to apply the Endurace Spray without getting it on your chrome wheels ?
    Re: Endurance Tire Black
    You can spray it on a tire foam applicator or rag then apply to the tires.
      I always spray it on a tire foam applicator. This way I only use enough for the tire to come black and not too much to make it sling everywhere.
        Tape some newspaper over the wheel surface using painters tape, and spray away, or cut out round cardboard and utilize the same way.
          Make sure your tires have been cleaned - a good all purpose cleaner and a tire brush should do the trick - and are fully dry. Then, as others have noted, rather than spray directly onto the tire, spray onto an applicator of some sort and then apply to the tire. Work it in thoroughly so as not to leave heavy residue in any texture or raised graphics on the sidewall. Let it dry thoroughly and you won't have to worry about any sling.
