Meguiar's wheel brush
  • Meguiar's wheel brush
    I just saw Meguiar's wheel Brush at Detailed Image. Does this wheel brush have good clearance between the brake caliper and the wheel?
    I have the large Wheel Woolie, it has clearance issues.
    I think you almost need the more bristly ones if you have tight clearance.
      I have the Daytona Speed Master Wheel Brush. I just don't like the splatter. My clothes get full of dots.
      Thanks for the reply!
        I've found it curious when using my Speed Master version. If I have lots of suds, I don't see the splatter. If I'm cleaning a wheel that has that unknown tire gel chemical that kills ALL suds, tons of splatter!
          I never tried but I'm guessing if you dump the brush in a bucket of cleaning solution, and soaking wet. The fluid will weigh down the bristle and help with splatter.
          With spray on products and agitate with the Daytonna Wheel Brush I always get splatter.. I read on a different forum if you twist the Daytonna while backing it out of the wheel it reduces the splatters. I'm guessing by twisting the splatter will get re-directed somewhere else, other than the user.
