M80 vs. M01 + M09
  • M80 vs. M01 + M09
    I already have a bottle of M01 (Fine Cut Cleaner) and M09 (Swirl Remover 2.0). Would I still need a bottle of M80 and why?
    Thank you in advance!
    Re: M80 vs. M01 + M09
    Well, you are working by hand, PC, etc?
      PC and later it will be (hopefully) rotary.
          M01 is Medium Cut Cleaner, which is for rotary only. I think the jump from M01 to M09 is too big and I’d definitely want to keep something around that was in between.
          The new version of M02 Fine Cut Cleaner is for rotary, DA, orbital or hand so you could conceivably use it instead of M80. It does cost more. It’s only a little higher on the aggressiveness scale. Personally, I like M80 too much not to keep it around. It’s higher in polishing oils than M02 so it has longer working time and you can usually skip the separate pure polish step.
          You can usually skip the separate polish step with M09 too but it’s so mild that I wouldn’t even bother trying to use it for reconditioning, just for removing swirls.
          PC.
            Originally posted by the other pc View Post
            I think the jump from M01 to M09 is too big and I’d definetely want to keep something around that was in between.
            I just realized I made a mistake, sorry. I do have Fine Cut Cleaner and that's what I typed in and meant but I also made a typo and entered M01 thinking M02.
            The new version of M02 Fine Cut Cleaner is for rotary, DA, orbital or hand so you could conceivably use it instead of M80. ... It’s only a little higher on the aggressiveness scale. ... You can usually skip the separate polish step with M09 too but it’s so mild that I wouldn’t even bother trying to use it for reconditioning, just for removing swirls.
            Should I interpret this as I don't need M80 if I already have M02 and M09, and after reconditioning once right with M02 followed by M09 majority of maintenance could be done with M09?
            I was under impression Meguiar's Professional Catalog for 2006 says M01 can be used with DA.
            Thank you again!
              Hey,
              That info in the catalog is a typo.
              M01 Medium Cut Cleaner is for rotary use only.
                sory whats a PC ?
                its not a personal computer huh ?
                alberto gorin
                known as gorin002
                  Hey,
                  PC stands for Porter Cable and usually is reference to their Dual Action Polisher, the 7424. Meg's offers the G100, essentially the PC but it has a life time warranty.
                    is there a pictuer on the website of this pc ?
                    alberto gorin
                    known as gorin002
                      Here you go....
                      G-100a
                      G-100a
                        ahhhhh thats it
                        i bought similar device mansmann was very cheap
                        now i know what pc is thank you
                        only need buy polishng pads
                        alberto gorin
                        known as gorin002
