Final Inspection vs. Last Touch
  • Final Inspection vs. Last Touch
    Besides the price, what is the difference?
    www.reflectionsautodetailing.biz
    Re: Final Inspection vs. Last Touch
    Final Inspection, M34, is essentially the Quick Detailer product in a larger volume. Also, I believe M34 is body-shop safe (Megs folks, please correct me if this is not true).
    The Last Touch product is NOT body shop safe. Both can be used as clay lube or detail sprays. The Last Touch can be diluted 1:1 where M34 cannot. Last Touch breaks down to $8-$9 per gallon when using it 1:1.
      The versatility of Last touch and the fact that Last touch is mot body shop safe are the 2 differences that come to my mind also.
      I regularly use Last touch and #135.
        Last Touch is a versatile mist & wipe product than can be used straight for your typical wipe down of light dust and fingerprints, or diluted 1:1 with water and used as a clay lube. Since it's in our Detailer Line it is available in large quantities (5 gallon and even 55 gallon containers). Here it's being used (along with several other Detailer Line products) at Manheim Auctions in Riverside, CA in 5 gallon containers and automatically diluted for final use:
        M34 Final Inspection is the only body shop safe mist & wipe product offered by Meguiar's. If you're going to use a product like this a body shop environment or where fresh paint is being sprayed, then M34 is essential.
          Come on Mike... we all know that's a photo of _your_ garage!
            So, if I'm understanding you correctly.. they're pretty similar but there's no reason to get Final Inspection for normal use.. so I just need to get Last Touch because it's more versatile.
              I just used last touch for the first time tonight. I was very impressed for a detailer. Nice shine and very slick
              There's no reason to become alarmed, and we hope you'll enjoy the rest of your flight. By the way, is there anyone on board who knows how to fly a plane?
                Last touch leaves a much higher gloss then Final Inspection. It also is much slicker.
                  For, a consumer who does high volume detailing, I suggest Last Touch.
                    That's a good way of looking at it... and the responses quoted below only reinforce that thinking.
                      You can tell the difference when a person used Final Inspection, rather than Last Touch. FI usually leaves a natural finish to your paint, while LT adds a boost of gloss.
                        I used to use FI, however, when I did the calculation on the cost, Last Touch was a lot better because you can dilute it for claying. Plus, FI costs more per ounce compare to Last Touch.
                          I use Final inspection as a wipe down after polishing.
                            I have not used FI yet, but i am very happy with LT.
                            Can`t see any reason to swap, other than what Chost is saying, I suppose FI would be a more suitable product for wipedown
                            1996´AUDI S6 AVANT QUATTRO
                              Originally posted by ColonelCash View Post
                              Final Inspection, M34, is essentially the Quick Detailer product in a larger volume...
                              Can anybody confirm this?
                              2011 F150 5.0L 4x4
