I'd like to know the differences between Ultimate Compound and M105. I've just ordered a sampler set of M105/M205 after reading up on various threads both here and on other forums. I’ve read one particular thread where a guy had problems with M105 and just today I think I ran into a similar problem with Ultimate – more on it later.
I’ve just got back into car detailing after a gap of about 25 years, so the biggest changes I’ve noticed are clay, DA machines, the new clear coats, the new polishes and of course the internet with all these wonderful forums. I’m still not sure about DA’s as compared to rotaries, but eventually after trying manually (by hand) I went with a DA polisher. I tried a rotary again, but found it difficult to handle, probably due to age constraints, so the DA appealed as something that wasn’t available previously.
I started with Meguiars consumer products, Ultimate Compound, Deep Crystal Paint Cleaner, Deep Crystal Polish and Deep Crystal Carnauba Wax. The results by hand were ok, but nothing stunning. The vehicle is a navy ’99 BMW. It has only been washed regularly since I purchased it, so it really had 11 years of neglect, so it was obvious after the manual attempt that I needed some more power.
As soon as I received the DA (DAS 6) I started out with Ultimate Compound with an orange pad. The DA came with Lake Country pads, Orange, White, Black and Blue and I added a Yellow. The result wasn’t very good (powdered up immediately) so I then switched to the Menzerna sampler products that came with the DA. The Menzerna products in order of aggressiveness in the sampler kit were P0203S, P0106FF, P085RD and APO60. Things started to happen very nicely with this combination.
At this stage I wasn’t all that interested in paint correction, scratches etc, I just wanted to get rid of 11 years of neglect, so I spent a considerable amount of time working a particular panel – the boot lid (you guys call it the trunk) until I felt confident with the DA and the various polishes and pads. Once I felt I had the proper technique and learnt the affects of each polish and pad I completed the vehicle. However I’m still disappointed with the result when I wheel it out in the sun. In the garage lighting, the finish looks terrific, but appears lifeless in the sun. Good, no swirls or marring, but lifeless, for lack of a better word. Park it next to a late model BMW and you wouldn’t really give it a second glance.
After finding a chart on another forum that listed UC as being more aggressive than P0203S, I then decided to start again with UC as the compound while I wait for my order of M105/M205 to arrive. It was after reading the thread I mentioned that I thought I'd experiment with UC. I started with a Yellow pad and UC. It did immediately powder, but I found you could then work through it and all of a sudden UC was really nice to work with and you could work it for a long time as it became translucent. There was a definite improvement with the finish. I then worked through the various Menzerna products with the various pads until I finished off with a black and blue pad and P085RD and then manually waxed with Deep Crystal Carnauba. The car look brilliant in the garage, but as I said before nothing special in the sun.
I’m hoping with the extra cutting power of M105 I’m going to improve the base, but I now find it hard to imagine, if I don’t have any defects now, how I’m going to get more gloss to the finish. After all you do recommend getting the finish correct with the least aggressive compound/polish.
I’ve read here that UC is based on M105 and that they are both non diminishing polishes as compared to the Menzerna range which are diminishing. I’m guessing that M105 is going to behave similarly to UC, but I would like a confirmation. Unfortunately, the Australian distributor doesn’t carry M105/M205, so I’ve got to wait on USPM. In the meantime I’ve gone down to 4” pads to remove a couple of scratches which I’ve successfully done with UC and an orange pad.
Is BMW paint considered as hard paint?
The technique I’ve been using is the Kevin Brown technique for pad priming and downward pressure and of course I’m regularly cleaning my pads.
Regards
Graham
Regards
Graham
