Meguiar's Rubbing and Polishing Compound review!
  • Meguiar's Rubbing and Polishing Compound review!
    So while I was in PepBoys, I couldn't help but pick up a tub of these new compounds. While the rocks in a can version from another manufacturer has suited me well in various applications, I wanted to see how well these suited up.
    So here ya go!
    The first thing I noticed was these were actually wrapped unlike the competition where I could just open it right up in the store (which surprised me to begin with). The next thing I discovered was that unlike the other red gritty stuff, Meguiar's Rubbing Compound was creamy and smooth, and I mean VERY creamy. I opened it up expected it to be solid and gritty but instead I almost spilled some out! Think vanilla pudding, and the same went with the Polishing Compound; same consistency. Another thing to note is that they have the old fashion polish smell; to some this may be good, to others it may not matter (I happen to not really care either way).
    A little history of my car first; it is a 1993 BMW 535i with what appears to be original paint (Jet Black; base/clear-coat), and have not got around to do anything to it yet after running out of supplies and having our entire dealership close down leaving me jobless. Needless to see from what you can see from the pictures the car is in dire need of a detail, and the paint is beginning to fail with some oxidation. So being machineless, I went ahead, washed, and clayed my entire trunk, so when you see the side by side, that is actually a clean trunk. Next, I started out by hand applying the rubbing compound and did 2 applications of it. Then, 2 applications of the polishing compound, followed by one layer of NXT2.
    Here is the untreated side:
    Here is the treated:
    And side by side:
    So far from perfect, but considering this was done by hand with a foam applicator and 2 applications, I have to admit I am VERY impressed! These products get an A in my book! Great job Meguiar's!
    Re: Meguiar's Rubbing and Polishing Compound review!
    Wow! I didn't think these products had so much cleaning power. I may have to pick up these two items and give them a try. Treated side looks very good!
    Tedrow's Detailing
    845-642-1698
      That's just fantastic!!! Thanks for the great write up!
        how strong are these products compared to lets say Ultimate Compound?
          Unfortunately I haven't tried Ultimate Compound so I can not say. What I can tell you is that these were made specifically for hand application only, whereas Ultimate compound is for hand/machine. When it comes down to how aggressive they are, you are always better off with a machine, so I would bet Ultimate Compound would win, but for hand application, someone else has to chime in for that info.
          But hey for hand application I really like the open tub, and the lower price point makes me give these products a thumbs up!
            In a way it's a hard comparison to make since these two products are designed for hand use ONLY. They are, obviously, quite effective though!
            And this is one of those times that, when we tell you HAND APPLICATION ONLY, we aren't kidding. And it's not because the products are overly aggressive with machine use, they just don't get along with it at all. You won't damage anything, but you won't enjoy the experience either.
            By hand though, they work beautifully.
              Stunning results by hand. What a great finish from a cheap product. Awesome. Thanks for doing the write-up. I think you may have just sold some people on this new product.
              Colin
                Nice Job! That is quite an improvement.
                Brian
                  Great write up and results. What a transformation after only 2 applications and by hand. It looks like another must have product.
                    Impressive results!
                      I have 32oz'ers of M105/205 and I still want to buy these products.
                      Calais Auto Detailing
                      CalaisDetails@aim.com
                        How much effort did you put behind the pad when working the product?
                          I've used both of these for spot scratch correction and they do a great job with NO micromarring.
                            +1
                            I don't have a machine yet but would like to remove some swirls...was it painstakingly hard on your arm (or arms) when removing them?
                            2011 Infiniti G37S 6MT
                            Black Obsidian
                              No not really; it was actually fairly easy. My biggest piece of advice is work on a cool surface and in the shade because these products DO NOT like the sun; they will dry out VERY quickly (as in almost as quick as you move the towel). What I did do though was have a spare spray bottle and spritz the surface in front of the towel. This left the towel slightly wet which also aided in removal, in which I used a second, dry towel to wipe it off. I also applied and worked in the product with a microfiber towel instead of a foam pad, and am relieved to say it did not leave behind any unpleasant messes with micro-marring or such. As far as removal, if it dries it is a BEAR to remove, so again make sure it is in the shade so it doesn't dry, and if you do have drying problems, simply use the apply/moist towel with the dry-remove towel approach with a spray bottle of quick detailer to put a few drops of water on the surface (this will re-liquefy the product).
                              The amount of effort does not seem to be anywhere near as much as ScratchX, so yes it is a very easy product to use by hand. Just be sure to work it in the shade! Working by hand though, you will quickly realize that it may be better to do the panel-a-day approach and do the car over the course of the week.
