So I have a 2011 Nissan Maurano and I decided to wet sand a few scratches off the car. I used 2000 grit paper and i did this before with no issues on a few scratches with a scratch kit. Well I decided to get rid of 2 scratches and started to lightly wet sand them out. I then used my PA 7424 with Hex-Logic polishing pad and Mags ultra cut compound (105) followed by mags ultimate finishing compound(205).
Well fist time I am using a pa so not sure if maybe i did something wrong but after using the 105 i did not see much of a difference. I see a few scratches but still very dull. I then switched to the 205 with white pad and polished it a few times like 4-5 times and it got a little better but it is not the same as the rest of the car. I can still see like a dullness to it.
How can I correct this? I did not post pics cause you can't see it. You can really tell from a angle. Am i using the wrong compound? did i not compound it out enough?
