Haze & Marring
  • Haze & Marring
    Could you please advice me on the issue I dealing with which is to how remove hazing and marring. Which one of the following you recommend:
    1- use Gold Class wax which it has polishing element
    2- use Meg#7 and follow up with GC wax
    3- use UP with finishing pad
    3- use 205 with finishing pad
    Thanks to all
    Re: Haze & Marring
    Either UP, or 205 with a finishing pad would be the way to go. The other two options have no cut to them.
      Can you comment on what you did so far that caused marring?
        Re: Haze & Marring
        I applied too much sealant and wax to one of my friend car.
          The wax may cause some haziness if not removed properly... But won't cause marring. Something else will have caused that.
            Re: Haze & Marring
            My friend washed the car prior I apply the sealant & wax - I'm not sure why I had hazing and marring . However, we washed the car again, polished using UP and LC crimson pad and applied the sealant & wax. Looks very good now.
              Re: Haze & Marring
              Glad it worked out.
              Maybe some thing in his washing caused some marring. Just don't want to keep causing it.
                Re: Haze & Marring
                I believe he used automatic machine wash, may be it caused the marring. For my self I use 2 bucket method.
                  Re: Haze & Marring
                  If you used #7, that **** is hard to get all the way off.
                    Re: Haze & Marring
                    M7 is ok if applied very thin. Also besure to follow the directions on the bottle by not letting it dry on the paint.
