So a somewhat heated debate came about on anther forum (non-detailing) and I wanted to get some MOL feedback. The subject was "is it bad to wax after every wash?"
I feel as long as you are using proper technique and quality products that you can wash and wax as often as you like. Doing so should only require a light polish once a year at most and should keep the car looking like new for years to come.
This is what started the debate...
Also keep this following thought in mind and it holds true no matter how good you are , how good your products and or towels are.
Anytime you touch your car , its going to put imperfections in it. Weither it be swirls , scratches or hazing. Polishing removes clear and sooner or later it will cause trouble.
So washing a car , waxing and polishing is only to make the apperance better. Basically the less you wash , wax or polish , the better it will look longer , except it will be dirtier.
Someone who washes it weekly will normally have a nice and clean car but will also work the paint less. If you wash daily your going to get more swirls much sooner. Same goes if you wash it every other week. It wont be as clean looking but it will also be less scratched over time....
You have to find the balance that works best for you
MOL thoughts?
MOL thoughts?
