Hi,i know there will be a lot of you into sound systems in your vehicle.
I have a '93 civic hatch.It originally had a cassette/radio 25w per channel and two front speakers(doors) 12w each and no tweeters.(all factory spec.)
I was really happy with the sound,(i'm not mad about big sound systems for the car).
The speakers were the paper type,normal.But they were starting to break,so I changed them.
I then put in a kenwood CD/radio 50w/(4ohm) per channel and replaced these speakers with a pair of 'Infinity' 5012's. They are 45w each (4ohm).(with inbuilt tweeters).
(I think the size is 4"). okay,i know these speakers are small,but the sound really *****.They distort at a hint of bass. The old set-up was better.
I reckon this is the same for car audio entertainment: For hi-fi's and studios,you normally put in a smaller speaker wattage than the output of the amp.This is because you can drive the speakers,whereas,if the opposite is done,you can turn up the volume too much creating amp distortion which damages the speakers.
So,I don't know if this applies to cars?
I reckon that these infinity speakers are better used in combination with other speakers?
Also,I checked the phasing,and I wired it correctly.
Anyone have any suggestions as how to get a good sound(like i had before),by replacing just these 2 front speakers? Even a different type of speaker?
Thanks.Ed.
Thanks.Ed.
