Before i had new calipers put on the car the brake pedel was very hard and i did not have to oush down a lot to stop the car(all the pads are less then 2 months old)I had new calipers put on my car cause I went with a powder coated pair, and now The car isn't to hard to stop and I push the pedal about half way down to stop the car but after I have the car stopped I can push the pedal all the way Down with no problem, I don't remember being able to do this before, i had the brakes bleed the day I put the calipers in and drove and then I had the brakes bleed the next day and it still does it, could it be because the calipers are new and need more pressure to push the piston out until they brake in or is it the master cylinder.
When the car is off and pump the brake pedel is does get hard to push down, it doesn't get completely hard to the point where I can't push it but it does not move a lot, it does get stiffer, the are no external leaks and I do not need to add brake fluid after driving,could it just be the calipers need to brake in?
