is there a way i can clean this up? i gots some scratches and swirls and what not on it ... i wanted to know if maybe SSR 1 would work or maybe SSR 2.5 without messing up the table haha .. and what would the process be i mean the table is inside the house i cant really wash it heh maybe clay
Wooden Table...
You might consider testing any products in a small area before attempting to work on the entire table. (Perform a Test Spot)
1) We're you planning on using a dual action polisher to apply the products?
2) What's the least aggressive product you have?
3) Do you know what kind of finish the table has on it?
least agressive product might be DC2
hmm as for finish i have completely no idea my dad was saying it was Cherry wood
also what speed would you recommend
Originally posted by zaink
yes i was going to use a dual action polisher
least aggressive product might be DC2
If it's a polyurethane type finish, then the best thing to do would be to test a product like the #9 Swirl Remover 2.0 and see if it works, if not you can always substitute a more aggressive product.
As for the Poorboy's SSR products, I have them, I have used them and I would suggest only doing a test spot to a small area an then inspect in good light. Always make sure you can make a small area look good with your choice of products and procedures before attempting to work on the entire finish.
You really want to test some product combinations and some speed settings in a small area before machine applying anything to the entire table. Make sure you can make one small area look good from beginning to end, i.e. polishing to waxing, before working on the entire finish. Dial your system down in one area and then cookie-cutter it over the rest of the table.
