I'm thinking about picking up a craftsman orbitial buffer, the one that just fits in your palm, from Walmart to use strictly for applying wax to save a little amount of time there. It has a 4000rpm rating.. Will this work for applying waxes? Also what other type of products will it help apply if any?
Orbital buffer- good for applying wax?
You an apply a wide range of products, but there's a difference between applying a product and removing a defect. Removing a defect would mean removing a little bit of paint and these tools usually just don't have the power to do this effectively.
So while you can apply a paint cleaner with one of these tools, and it will clean surface contaminants off, you probably won't be able to remove swirls and scratches, at least not effectively.
If you goal is to simply apply a polish and/or a wax then they are great for this and unlike your hand they won't get tired.
I say Go for it!
Originally posted by 96greenmustang
I have the money for a G-100 but I'm afraid I will damage my car from lack of experience..
Its your decision, make the decision on what you feel more comfortable with. Maybe start with the Craftsman get use to it then move on to a PC.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by gb387
There should be no worry about a G100 damaging your paint.... very safe tool. ...
Since you have the money for the G-100 already anyway there’s little point in getting the other orbital. If you want to start out with a weak motion that just applies a product but can’t remove any defects you can just turn the G-100’s speed down and not put any pressure on it.
PC.
