Hi Guys,
I know there is a lot of good info about buffing a special car
like this, and i spend a lot of time reading all kinds of post and
topic's about it.
Also i know that it's almost impossible to give an answer on a
question like " how hard a finish could be " and that the advice
would be like " go out and work on the paint and find out your
self " and that's just what i did.
First a picture of the car:
Here i have some info about this car:
* 1970 Ford Mustang Fastback Mach1
* Single stage paint, repainted approx. 15 years ago
* Paint color is Grabber Green
* Looks pretty good, but has light swirls and tiny scratches
Here is a picture made from a little distance:
This one is made from a little closer by:
First i made a test spot by hand using:
* QD for quick cleaning a square foot of paint
* Quick detailing Clay System and QD
* Scratch X on a appl. pad with enough pressure ( 3 times 5 min.)
* DC Paint cleaner
* Wiped it all of with a clean MF
But this had no effect on the swirls and scratches, it felt clean and
smooth to the touch and a bit more shine but that's it.
Than i tried, on the same spot my machine it's a eccentric sander ( Bosch ) using this:
* Scratch X mixed with DC Paint cleaner 50/50 on a W8006 Polishing pad several times in total time 15 min.
* Wiped off with a clean MF
Again it had no effect whatsoever, my pad became a little Greenish but it did leave the swirls and scratches right in.
This one was made after i used the machine:
I expected that the paint could be hard but this hard
I guess i ran into the machine and products limitations and i
have to try to get my hands on some heavier stuff.
Now you know by now that we can't buy a PC or whatsoever
and i never used a real rotary before so i was thinking to purchase a Makita BO6040 so i have a orbital and a ( limited ) rotary buffer at the same time.
Now my questions are these:
* Would #83 and #80 be aggressive enough or will i have to
use #84 or even the #85 compound?
* Is it safe to use my W7006 ( if needed ) on the cars finish?
Further more i need some info about the black " sticker " on the
hood, it's not painted but it made from some sort of self adhesive
material and it has lots of cracks on it.
Like you can see on these pictures:
So has anyone experiences with this kind of severe cracks or does
anybody have any kind of suggestions about the best way to handle this
i know i can't remove the cracks out of there but maybe i can
make them look less noticeable
I guess the cracks come from the heat of the engine below
so a new one should turn out to be just the same in a short while
at least that's what i think.
I really could use some help on this, because it's the first time
for me to work on a very special car like this one.
Thx in advance
topic's about it.
* DC Paint cleaner
Thx in advance
