NXT won't bond to #26?
  • NXT won't bond to #26?
    On another board I was reading that it was not recommended to use NXT over #26 as NXT won't bond to the #26.... is that right? Can it be used the other way, NXT then #26. My plan was to use both next time I wax my truck but not sure what way would be best.
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Yes, if you want to use them together, I think NXT then #26 would be the most reasonable way to do this. I'd give the NXT at least 24 hours before you put #26 on top of it.
    1990 Corvette ZR-1 Bright Red with Red interior Hear it!
    2002 Aurora 4.0 Cherry Metallic with Neutral interior Hear it!
    1997.5 Regal GS Jasper Green Pearl with Medium Gray interior
      I think that is probably some Zaino thinking being applied to NXT. Meguiars designs their products with compatibility in mind. With that being said I would probably apply #26 over NXT only because I would want the most durable product as my base layer.
      Bob
      2001 Laser Red Mustang GT Coupe
      Click Here for pics of my Mustang
        Never thought of it that way....
        Brandon
          The whole bonding issue is way over blown. Just apply the was any way you like and then you be the judge.
          I have an upcoming post about bonding that I hope will enlighten a few people on the subject. Here's a hint... mold release wax.
          Mike
            Think about this: No matter what you put on or over or whatever, can you imagine ever seeing it flake off?
            Nope, neither can I. As long as it's shiny and the water beads, I'm going to figure everything worked out OK.
            Tom
            As the light changed from red to green to yellow and back to red again, I sat there thinking about life. Was it nothing more than a bunch of honking and yelling? Sometimes it seemed that way.
              Tom
              You know Tom, when plain sense makes common sense, there's no more need to make any other sense.
              Mike
                again its me. what product is #26
                TNX
                CONMD
                  FROM Meguiars web site:
                  Hi-Tech Yellow Wax #26
                  Enhances the depth of your car's color. This unique professional-grade formulation blends premium yellow Carnauba wax with silicones, polymers and other specialty waxes It provides maximum high gloss protection while it actually deepens your paint color. No wonder Hi-Tech Yellow Wax is the professional's choice! Made For Professionals
                  Got to www.meguiars.com and search for Hi-Tech Yellow Wax
                  I think this is a very easy was to apply and remove, it will leave a great finish.
                  Brandon
                    Tom
                    My thoughts exactly!...I've always thought that bonding issues were overblown anyway...Just my .02 on the matter.
                    r. b.
                      Tom
                      no hearing what everyone has to say I see your point.
                      Brandon
                        I gave the NXT/#26 combo a testdrive with my first application of NXT recently. I only applied it to two test areas however...
                        My observations:
                        After applying the NXT, I was blown away by the gloss and general reflectivity but hoped for just a bit more depth as I think depth is key on a dark vehicle.
                        I allowed the NXT to 'cure' for 24-36 hours and brought it back out into the daylight and noted that the depth seemed to have improved (along with the natural light that I was utilizing to see the vehicle's finish).
                        From here, I wanted to give the #26 a try. The NXT was AWESOME but, I wanted to see if I could raise the bar a quarter inch.
                        I applied #26 with the PC and polishing pad over half of the hood and half of my tailgate. I removed with a DF Concours MF towel and sat back and examined.
                        At first, I didn't see a big difference but, as time went on, I started to note that the test areas seemed to have a little more depth and more of that classic carnauba look. Indeed, there was a noteable difference... I say this because even my wife (who is not very savvy when it comes to vehicle appearance) said that she could tell a difference.
                        To date, the jury is still out on if there were any problems with the NXT / #26 combo but, I suspect that they layered well. Further, I'm sure that the carnauba will enhance not only the luster/depth but also the level of protection.
                        So far, it's a DEFINITE two thumbs up from me!!!
                        -The Final Detail-
                        Lagrange, Kentucky
                        thefinaldetail@insightbb.com
                        CLICK HERE TO VISIT MY GALLERY
                          Re: NXT won't bond to #26?
                          gb387,
                          Mike's recent thread about bonding pointed out some interesting theories on the bonding issue. Still, if it were me, and I were "trying" to layer, I would be appying the #26 over a couple light coats of NXT. If for no other reason, I've found the #26 to have almost no cleaning ability, and shouldn't remove the NXT. On the other hand, the NXT has a "tiny" amount of cleaning ability that might remove some of the #26.
                          Then again, Mike's point about contamination that is not always cleaned off the paint with washing and/or QD'ing is a good point. Doesn't make a lot of sense to layer over contamination.
                          Just my 2 cents.
                          Having said all that, one would think that the better one maintains their paint, the more apt they are to get away with layering. For someone who simply washes once a week or so, and then applies a coat of wax every 4 to 6 weeks........... layering may not be such a good idea........... without some "cleaning" of the paint surface before, or during the waxing process.
                          Boss_429
                            I just posted this to this thread,
                            It used to be that applying a wax to often was considered a bad thing because you could get a wax build-up on your paint.
                            Now days, a wax build-up is a good thing, only it’s called, Layering.
                            Go figure...
                            (The times they are a changing.... "Bob Dylan")
                            Mike
                            Mike
                              i just want to share my experience on 'layering' since i often do this at least once a week, everytime i got my car washed.
                              i prefer applying #26 first after applying a coat of #7. this way the color of the car deepens further as compared to applying a polymer sealant (#20) or the medallion paint protection directly after #7.
                              i really do love to experiment on what products to layer that will give the best shine and protection, and #26 topped with any meguiar polymer products gives the best shine and protection so far. i havent tried the NXT tech wax since it is still in-transit.
                              attached is a sample reflection picture. please focus on the reflection of the plant on the rear door... i am not good in taking pictures and the picture was taken using a camera fone! next time i'll use a videocam in taking pictures...
