NXT Spray Wax, wax hardened in the tube and now won't spray
Results 1 to 3 of 3
Thread: NXT Spray Wax, wax hardened in the tube and now won't spray
    panteeze
    Guest
    Has this happened to anyone? Any suggestions for a fix?
    Registered Member Pete-FWA's Avatar
    Oct 2005
    546
    21
    Soak the assembly in warm water.
    Will the tube come out of the spray head? If so, pull it apart and soak the pieces this way...should help loosen things faster.
    Do you have anything thin enough to get in the tube and pick out any of the wax without actually breaking the tube? i.e. toothpick
    See the big picture, enjoy the details
    Meguiar's Customer Care Team Tom MacDonald's Avatar
    210
    19
    warm or hot water soaking will work to disolve this. If you ar e in a hurry you can get a long wire and run it through the tube to unclog it. Because the product is a spray wax this can happen if it sits for long periods of time. If you know you are not going to be using it. Give it a good shake from time to time to keep it from settling.
    I hope this helps you.
    Regards,
    Tom
  1. NXT quik spray wax-Gold class spray wax.
    By 03mach1 in forum New Product Suggestions
    Last Post: Jun 20th, 2008, 01:13 PM
  2. Which to use, NXT Spray Wax, Gold Class Wax, Show Car Glaze
    By rdv350 in forum Consumer Line - Product Reviews
    Last Post: Sep 7th, 2006, 06:55 AM
  3. NXT Spray VS Spray Wax
    By hal1 in forum Detailing 101
    Last Post: Aug 8th, 2005, 04:09 PM
  4. NXT Spray Wax and Gold Class Clear Coat Wax
    By nyyanks81 in forum Consumer Line - Product Reviews
    Last Post: May 6th, 2005, 06:31 AM
  5. Spray Wax on NXT Tech Wax
    By S60slipstream in forum Meguiar's Consumer Line Products
    Last Post: Sep 16th, 2004, 06:23 PM
