Detailing under the car - Question
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Detailing under the car - Question
    May 2005
    158
    15
    Hey guys,
    Just a question... how do I detail/clean under the car? I've attached a pic of which portion I mean. Anyway to "dress" it?
    Thanks!
    Registered Member Jonesey's Avatar
    Nov 2005
    50
    140
    15
    I either pressure wash or scrub (or both) the loose dirt off, then use spray on tire cleaner followed by spray on tire dressing. (The NXT line) Works great and really finishes the job off.
    Right now the rest of your car looks GREAT, but my eyes keep getting drawn to the mud.
    Glenn
    38
    19,049
    235
    I spray in some All Purpose Cleaner with the foaming spray head (DO NOT USE SIMPLE GREEN), let it sit, agitate some, etc, then rinse off.
    I come back after detailing car and spray in some All Season Dressing, and spread it around with a foam paint brush.
    Meguiar's Accounting Manager Brian Catalano's Avatar
    Oct 2005
    96
    14
    You want to really restore the 4 corners of your ride?
    Take off each wheel, clean the inside and back of each wheel with APC, then scrub the fender liner, frame and all suspension components with APC (not just the visible ones! 8-). Follow up with a liberal dosage of Tech Protect, then torque the wheels back on to the Mfg recommended spec.
    It will look like a new car.
    Brian
    Registered Member Pete-FWA's Avatar
    Oct 2005
    546
    19
    Something I found to last even longer was cleaning these areas, then spraying with a black paint. We used a chassis black paint through a spray gun, but good aerosol spray cans will do the job.
    This makes maintaining the look much easier than just applying tire dressing. Overspray is the only enemy in this situation, but aplied properly, one can avoid problems.
    See the big picture, enjoy the details
    Oct 2005
    96
    14
    Eeeek! You're kidding, right? Please tell me you're kidding. Even if you're not, please tell me you are.
    Brian
    Sep 2004
    1,523
    30
    the way i clean in the wheel wells is... turn the tires in the left direction when it's parked, as it will be easier to get inside and do a thorough job. i then use a wet sponge with car soap, rinse, and then spray hyper dressing and walk away..... done.
    Oct 2005
    546
    19
    Why does this bother you? I take it you've not done this before.
    My suggestion is an oversimplification of the process. I would be glad to explain in detail if you're interested.
    Registered Member WaspHunter's Avatar
    Jan 2006
    225
    16
    If you're just cleaning, then turning the wheels imacarnut's way should be fine.
    I agree with Pete-FWA, it's sometimes done on show cars (pot belly black also works if you only have a brush). Much cheaper than the dedicated one-piece guard/wheel well combos.
    Gil A. Castillo
    Registered Member electricgreen's Avatar
    Mar 2004
    225
    17
    The flat black paint works better on older cars that have metal fender aprons exposed, vs newer cars with the plastic "wheel wells". On my '00 stang, I use QD & a towel to clean, then Tech protectant to shine. If you do take your wheels off to do this, take the opportunity to clean up the inside of your rims!!
  1. question on detailing
    By 20ranger08 in forum Detailing 101
    Last Post: Mar 3rd, 2009, 03:41 PM
  2. Question about detailing
    By chvyeter in forum Detailing 101
    Last Post: Jan 1st, 2008, 01:05 PM
  3. new to detailing.. PC question...
    By jmanero123 in forum Detailing 101
    Last Post: Mar 2nd, 2007, 03:26 PM
  4. Detailing question
    By realitycheck in forum Detailing 101
    Last Post: Aug 9th, 2006, 07:03 AM
  5. Detailing Process for Lambo Gallardo at WAC Car Detailing
    By WAC in forum Show Off Your Latest Detail Work
    Last Post: Sep 19th, 2004, 07:42 AM
