.: NXT spray wax...foam or even coat?! Dry or wet?!
  • .: NXT spray wax...foam or even coat?! Dry or wet?!
    Last weekend I clayed/ColorXed/NXT Paste.
    May wash the car on next friday and I'd like to know...is it ok to apply a coat of NXT spray wax after that?!
    Should I use even coat applicator or foam pads?! Is it better to wipe it dry or just after applying it?!
    Thanx, all.
    Andre
    well the way i do it is by applying it by the even coat applicator. The pad should be dry. Also let the spray wax haze a bit which shouldnt take long hope it works out for you
      Re: .: NXT spray wax...foam or even coat?! Dry or wet?!
      Here's the how to article on the NXT Spray wax.
      Thanx, all.
      Andre
