No clear coat.
  • No clear coat.
    What products can or should I use with a non clear coat paint. I used NXT and the car looks great. I am concerned that if I continue to use this since it has a mild polish it will continue to remove paint. I wanted to use just #7 on a regular basis. The car is garaged and under a cover. It is a 1986 Mustang GT (Jalopena red) with 30K original miles and stock.
    __________________
    He waxes desperately with imagination.
    You can use the same products on clear coat, as well as single stage paints. Meguiars products are safe for both.
    Using #7 topped with Nxt will look great, and if it is garaged and everything, will last for quite a while. You can use a Spray Wax even after your intermediate washings.
      Do you think the use of NXT on a regular basis will remove too much paint?
        Nxt wax shouldn't remove any paint. Cleaners remove a little clearcoat so i would think it would be the same for single stage. Someone can chime in if i'm wrong.
          You have to remember that letting air move past the paint will cause a few molecules of paint to come off, so removing paint is all relative.
          You can apply the Nxt all you want without any worries about the paint. The cleaners in Nxt, and other Meguiars waxes, are all very very very mild, and should not be confused or compared with an actual cleaning step.
          On that note, a cleaner like DC#1 is also very mild, and would be safe to use every week for years, if for some reason yo uactualy needed to.
          The problem comes from using old fashioned, very abrasive products, or an untrained person applying things with a rotary. Or both.
          You can safely wash, clay, clean, polish, and wax your car every month, or every couple months for years. Using a quality car wash, some clay, and a nice paint cleaner will help prep the surface best, and your polish and wax will look better and even last longer.
          Give these a bit of a read over as well, they might help with some of your concerns, as well as clear up what process to use. Or start more questions..
          Step 1 Wash
          Step 2 Clean
          Step 3 Polish
          Step 4 Protect
          Step 5 Maintain
          A Lesson From White Paint
          Measuring Clear Coat Thickness
            Thanks!
